Connection lost after disable VLAN
During my tests, I observed that after certain configuration changes, it is no longer possible to log in. The access point loses its connection, and the issue can only be resolved by performing a factory reset on the device. This behavior does not appear to be normal and should be investigated further.
A specific example: The issue occurred immediately after deactivating the VLAN function under the "VLAN Settings".
The access point is connected via the Zyxel switch
NWA50AX PRO
Firmware: V7.10(3) 2025-06-29 07:27:38
Best Answers
With VLAN 1 as native checked this means the AP is on a untagged network I have (on my NWA50AX PRO) changed this so my AP is on VLAN 4091 and native unchecked this means the AP must be on a the VLAN 4091 tag network.
Hi @Montland,
"As Native VLAN" is checked, that means the packet will be untagged.
Please reference these FAQs for more details:
Understanding VLAN Settings on Zyxel AP — Zyxel Community
What is the option "As Native VLAN" on the AP's VLAN setting? — Zyxel Community
Zyxel Melen0
Hi @Montland,
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
