Wireless Clients shown wired
Hi @Oliver_Fehn
Thanks for reporting. Could you enable the Zyxel support access again so we can access and check?
Zyxel Melen0 -
Hi @Zyxel_Melen,
its done.
Hi @Oliver_Fehn
Thanks!
Could you help to point out which client is wireless client but been recognized as wired client?I found the issue devices. We are going to investigate this issue. I will update you once I have further information.
Zyxel Melen0 -
Hi @Oliver_Fehn
Our engineer found that the issue vanished after topology change, the Flur AP was a mesh repeater when the issue occurred, and issue vanished when the Flur AP is not a mesh repeater but an AP. May I know why you change your topology?
Zyxel Melen0 -
Hi @Zyxel_Melen,
I change the topology and connect the Flur AP wired, because i think its better. Now the Clients shown correct, but the Flur AP now shown twice in unter the Clients List when i switch on „show Nebula devices as clients“.
Hi @Oliver_Fehn
Thanks for update. We will keep tracing this issue, which could be another issue when the client connects with mesh repeater AP.
The Flur AP shown twice is because one MAC address is :2A and another is :2B. We are checking why the MAC address :2B was learned. I will update you once I get further information.
Zyxel Melen0 -
Hi @Zyxel_Melen,
Thanks for the support.
Hi @Zyxel_Melen,
I think restarting the router fixed the issue. The Flur AP is now only displayed once.0 -
Hi @Oliver_Fehn
Thanks for the update. Let me describe the root cause for this case.
The Flur AP was a mesh repeater AP, that use :2B to request DHCP IP. The USG Lite 60AX somehow kept the :2B in its client list although AP use :2A to request DHCP IP after change back to wired uplink.
We have replicated this issue and investing it now. I will update the result once I get further information.
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 496 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
