NSA326 meta repo installed but not working
I just installed meta repo by web_prefix http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/ Download successful, installed packages successful.
But after all, apps do not work.
This is the system message:root@NAS326 :/i-data/ffb0d2f0/.PKG/Transmission/config/Transmission# rsync
/i-data/ffb0d2f0/.PKG/RandomTools/bin/rsync-3.1.1: error while loading shared libraries: /i-data/ffb0d2f0/.PKG/RandomTools/lib/libiconv.so.2: file too short
root@NAS326 :/i-data/ffb0d2f0/.PKG/Transmission/config/Transmission# mc
/i-data/ffb0d2f0/.PKG/MidnightCommander/bin/mc: error while loading shared libraries: /i-data/ffb0d2f0/.PKG/MidnightCommander/lib/libiconv.so.2: file too short
Then I checked files and they are 0 byte. What went wrong?
Welcome in the wonderful world of embedded Linux hacking. I compiled those binaries for the NSA series, which have libiconv.so.2 in the library search path. Then ZyXEL came with the NAS series, which doesn't have libiconv.so.2. I could have created different packages for the NSA and the NAS, but instead I decided to put a check in the startscript. For rsync that is in .PKG/RandomTools/etc/custom_startscripts/00tools:
if [ "${PKG_FIRMWARE}" = "4" ] ; then for tool in $RANDOMTOOLS_LIBICONV $RANDOMTOOLS_MAGIC do SymlinkTool $tool done else local libiconv=${PKG_ROOT}/lib/libiconv.so.2 [ ! -f ${libiconv} ] && wget ${PKG_DOWNLOAD_URL}/libiconv.so.2.gz -O - | gunzip >${libiconv} for tool in $RANDOMTOOLS_LIBICONV do ScriptToolEnv $tool "LD_LIBRARY_PATH=${PKG_ROOT}/lib" done for tool in $RANDOMTOOLS_MAGIC do ScriptToolEnv "$tool" "LD_LIBRARY_PATH=${PKG_ROOT}/lib MAGIC=${PKG_ROOT}/share/misc/magic.mgc" done fi${PKG_FIRMWARE} is 5, on a NAS, and so it checks if libiconv.so.2 exists, and else it downloads it from ${PKG_DOWNLOAD_URL}. That variable should point to the place where the package (RandomTools in this case) was downloaded, what in your case should point to http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw5/. But it didn't, or your box wasn't online when you started RandomTools for the first time. That yields a zero byte libiconv, due to the gunzip.
The actual cause is hard to trace, but the remedy is simple. Download libiconv.so.2.gz, and extract it to the right lib directory.
removed 0byte libiconv.so.2 file from MC and rsync lib directories and copied the downloaded libiconv.so.2, both are successfuly started and run. thx!
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
