Nebula Pro Trial Pack License Not Working
Hi @Lohkamp
You see the banner is because enable the Nebula Pro pack trial will not change your organization type, if you mentioned the pro trial license is in the License & Inventory > trial tab.
Although the organization type is base pack, you can still use all of the features including those that require the organization type to be PLUS/PRO pack.
Zyxel Melen0
Hi @aduw1ng,
When the Nebula Pro Pack trial is activated, you will see your organization is using the Base pack.
It is a normal behavior, you could check the Pro Pack trial status in Organization > License & Inventory > trial.
Hope it helps.
Zyxel Melen0 -
We have the same problem - activated the pro trial license for a new customer but it shows (in German) "in Bearbeitung" (= in processing) for several days now.
Hi @Lohkamp
Zyxel Melen0 -
Ok, thank you very much.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
