H series 1.35 FW download is impossible
GiuseppeR
GiuseppeR Posts: 667 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
when you go to:
https://www.zyxel.com/it/it/support/download?model=usg-flex-100h
to download the firmwares of H series (in the link the example for 100H) you cannot do them.
You see this:
But when you click on Download green button you get this error:
How can I solve this?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,630 image  Zyxel Employee
    Update:
    The firmware file download for USG FLEX H series will be available on August 20th in the Zyxel Download library.
    Zyxel Melen
«1
  • Zyxel_Melen
    Hi @GiuseppeR
    Due to some reason, the firmware file isn't available on download library and myZyxel. I assum you are using a date code firmware that cause you can't use cloud upgrade. Let me send you the file in private message.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I was referring to devices just out of the box, I tried also with 200 and 500 H series but no way to download firmwares.
    As you can see I have a 100 HP online:
    So I went to Zyxel Library:
    and clicked on this link:
    https://portal.myzyxel.com/my/firmwares?fw_version=1.35(ACII.0)C0&model=USG%20FLEX%20100HP
    But no results:
  • Zyxel_Melen
    Hi @GiuseppeR
    This limitation is for all USG FLEX H sereis. We are processing to let the firmware file available on these web page, but I don't have any ETA info currently.
    Zyxel Melen
  • GiuseppeR
    edited August 2025
    Hi @Zyxel_Melen
    so the only way to update them is to let them go online and check their firmware by themselves?
    No way to check the hash?
  • Zyxel_Melen
    Hi @GiuseppeR
    Cloud upgrade is the first method, which the device will check the hash by itself. Or, contact us (Zyxel agent, ex. @Zyxel_CSO ) to get the file.
    Zyxel Melen
  • GateArray
    GateArray Posts: 10 image  Freshman Member
    First Answer First Comment Friend Collector Sixth Anniversary
    I'm stuck too….
    There is any way to get 1.32 and 1.35 firmware for 500H?
    the first access is blocked to firmware download page and I'm not capable to access and change the IP cfg.
    PeterUK Posts: 4,427 image  Guru Member
    edited August 2025
    If your getting past connect to internet and time I don't see how you can't download the firmware? hope this it not a case of old stock firmware not linking up to firmware upgrade server issue?
  • GateArray
    It is the first time I've switched on the device.
    I would like to setup the IP network as the first step before connecting the firewall to the network.
    Actually I can't access to the normal interface…. i didn’t find any way to bypass the crappy "https://192.168.168.1/zyInitWizard"
    This situation is unbelievable…
    can you not connect it to some LAN with internet?
  • GateArray
    Of course I can. But this is not the point.
    It not acceptable that you "MUST" have a test / preparation environment with internet connection to get the way to simply access to the main menu.
