Scheduled Switch reboot
LukeArchbold
LukeArchbold Posts: 17 image  Freshman Member
Hi all,
Is there any way to schedule a switch reboot
    PeterUK Posts: 4,272 image  Guru Member
    I'm not seeing this and then it depends on what switch model? Maybe there is a way to do it be ssh script?
    Or get a smart plug or a timer plug.
  • Zyxel_Tina
    Zyxel_Tina Posts: 458 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers First Comment
    edited August 19
    Hi @LukeArchbold,
    Currently, our switches do not provide a direct function to schedule a full device reboot.
    To better understand your requirement, may we ask:
    • Which switch model are you using?
    • What is the purpose of scheduling a reboot (e.g., restarting the whole switch itself, or just resetting connected PoE devices)?
    If your actual goal is to reboot the connected PDs instead of the switch itself, please refer to the following articles (available for the PoE models only):
    If you could share more details about your setup and goal, we’d be glad to provide more tailored advice.
    Zyxel Tina
