Scheduled Switch reboot
Hi all,
Is there any way to schedule a switch reboot
I'm not seeing this and then it depends on what switch model? Maybe there is a way to do it be ssh script?
Or get a smart plug or a timer plug.
Hi @LukeArchbold,
Currently, our switches do not provide a direct function to schedule a full device reboot.
To better understand your requirement, may we ask:
- Which switch model are you using?
- What is the purpose of scheduling a reboot (e.g., restarting the whole switch itself, or just resetting connected PoE devices)?
If your actual goal is to reboot the connected PDs instead of the switch itself, please refer to the following articles (available for the PoE models only):
- (Nebula) PoE schedules: You can configure PoE schedules via NCC at Site-wide > Configure > Switches > PoE schedules.
- (Standalone) PoE Time Range Setup: This allows you to schedule when PoE power is enabled or disabled for specific ports.
- Auto PD Recovery: Certain models (such as the GS1350 series) support this function, which automatically reboots PoE devices when they become unresponsive.
If you could share more details about your setup and goal, we’d be glad to provide more tailored advice.
Zyxel Tina
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
