Is it possible to set Wi-Fi output power on USG LITE 60AX, e.g. 50%?
Hi @Pe990
Yes, you can adjust the Wi-Fi output power on the USG LITE 60AX, but it's set in dBm rather than as a percentage.
To configure this in the Nebula Control Center (NCC):
- Navigate to `Site-wide > Configure > Security router > Radio settings`.
- Scroll to the bottom of the page.
- Select your USG LITE 60AX model and click "Edit."
- Locate the "Maximum output power" field to adjust the value, which typically ranges from 1 to 30 dBm.
Zyxel Melen0
Hi @Pe990
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
