What's the default admin and root password for the Zyxel EX3301-t0?
I recently bought the Zyxel EX3301-t0 as a second-hand router, but it's super locked down. You can't upgrade or do basic stuff. Most importantly, you cannot configure pppoe and make good use of it. It came with a generic username password of "user" "user". In an attempt to unlock the full capabilities of the router, no generic password works for this model. I've tried so many generic passwords with no luck. It was reduced to a basic switch right now. I flashed it with this generic firmware from zyxel's website: 5.50(ABVY.6.2)C0. It would be great to know how the router generates the passwords so you can replicate it yourself. If you have anything useful on the matter, don't hesitate to contact me here.
it could be the previous owner might have its ISP settings and login credential. i would check with seller about it.
You've noted you've flashed it with this generic firmware from zyxel's website: 5.50(ABVY.6.2)C0, could you describe how have you done it. Within web interface or ssh access. I have similar situation but can't connect with credentials written on sticker to ssh…
Why can't you do a RESET, as described in the user guide for the EX3301-T0 in section 2.3.3 ?
Then the default admin password will be the same as the one on the sticker on the back of the unit
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 107 Security Highlight
