Unable to install SSH package on NSA325 v2
Matej55
Matej55 Posts: 5 image  Freshman Member
Hi, please advise..: Unable to install SSH package on NSA325 v2. What to do about it..? I need to search for deleted data and to do this, I need to enable SSH service. Unfortunately, it is not available in the settings and cannot be installed from the package list. Firmware version V4.81(AALS.1), MacOS Sequoia.
Thank you..
  • Mijzelf
    Mijzelf Posts: 2,986 image  Guru Member
    ZyXEL has shut down their package server, so you can't install their packages anymore. Now you have a few options. If telnet is good enough for your purpose, you can use the Telnet Backdoor.
    If not, I have a backup of the ZyXEL repo here. The easiest way to use that is by installing MetaRepository, and adding my backup as extra repo. (Make sure you add a http url, not https).
  • Matej55
    Thank you, but both links report dangerous sites to me…
  • Mijzelf
    Really? Who or what reports so? On base of what? And which 2 links, I gave you 3.
  • Matej55
    http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/
    https://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/
    Dangerous site
    We have blocked access to the site because it poses a serious security risk. O2's security service protects you from infected and fraudulent sites.
  • Mijzelf
    OK. That doesn't tell if the site is blacklisted, or that an heuristic scan told the site is dangerous.
    I don't get it. The site doesn't even use javascript. What you see is what you get. OK, it contains download links to binary files, but I can't imagine O2 to download proactively a linked file to analize it. (and even if, the files are rather default Linux/arm packages)
  • Matej55
    Okay, I'll ignore the warning and try downloading it. I'll let you know how it goes. Thanks anyway...
