Unable to install SSH package on NSA325 v2
Hi, please advise..: Unable to install SSH package on NSA325 v2. What to do about it..? I need to search for deleted data and to do this, I need to enable SSH service. Unfortunately, it is not available in the settings and cannot be installed from the package list. Firmware version V4.81(AALS.1), MacOS Sequoia.
Thank you..
ZyXEL has shut down their package server, so you can't install their packages anymore. Now you have a few options. If telnet is good enough for your purpose, you can use the Telnet Backdoor.
If not, I have a backup of the ZyXEL repo here. The easiest way to use that is by installing MetaRepository, and adding my backup as extra repo. (Make sure you add a http url, not https).
Thank you, but both links report dangerous sites to me…
Really? Who or what reports so? On base of what? And which 2 links, I gave you 3.
http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/
https://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/Dangerous site
We have blocked access to the site because it poses a serious security risk. O2's security service protects you from infected and fraudulent sites.0 -
OK. That doesn't tell if the site is blacklisted, or that an heuristic scan told the site is dangerous.
I don't get it. The site doesn't even use javascript. What you see is what you get. OK, it contains download links to binary files, but I can't imagine O2 to download proactively a linked file to analize it. (and even if, the files are rather default Linux/arm packages)
Okay, I'll ignore the warning and try downloading it. I'll let you know how it goes. Thanks anyway...
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
