Replacing ISP firmware on AX7501
Thanks, this is what I'm getting:
ftp> cd fw 250 OK. Current directory is /fw ftp> bin 200 TYPE is now 8-bit binary ftp> lcd 5.17(ABPC.6)C0 Local directory now …/5.17(ABPC.6)C0 ftp> put V517ABPC6C0.bin 200 PORT command successful 150 Connecting to port 51374 226-File successfully transferred 226 13.623 seconds (measured here), 5.86 Mbytes per second 83756032 bytes sent in 13.5837 seconds (5.8803 Mbytes/s)
At this point, the LED starts blinking red.
I've seen that in the other posts mentioning updates via FTP there is a response along the lines of
updating firmware, please wait, but I'm not getting anything like that.I'll leave the device for a while longer now, before checking if there was any effect.
So, I managed to find some logs. I'm getting the following error:
flashImage.264: Flash whole image... ERROR: NAND flash block size 256KB does not work with an image built with 128KB block size bcmNandImageSet failed, rc=-1ERROR[flashImage.296]: Failed to flash whole image ERROR!!! Image could not be flashed. Firmware Upgrade fail File Upload
Looks like the image of the firmware version I'm trying to flash is not compatible or maybe I'm uploading it wrong? Any advice would be welcome
So i see you have the right FW . Blocksize could be adapted in the FTP Program ?
https://www.ibm.com/docs/en/zos/2.4.0?topic=protocol-blksize-ftp-client-server-statement
@Averethel Were you able to flash the firmware? I'm in the same boat with an AX7501-B0.
- 591 USG FLEX H Series
- 478 News and Release
