Widget malfunction - "Clients by manufacturers"
Best Answers
Hi @GiuseppeR
Sorry for the delayed update. This issue has been solved last Tuesday. We also add a monitor log to monitor this issue to prevent similar issues from happening.
Zyxel Melen0 -
Hi @GiuseppeR
I checked with our team and there was no issue after we add the monitoring tool. About this issue, it is more likely the MAC address is not able to verified. I used the wireshark OUI Lookup Tool and get the same result. So, the issue is from the device's vendor, not Nebula can't verify the MAC/OUI.
Zyxel Melen0
Hi @GiuseppeR
I checked some of our site's clients and had the same issue.
Could you help to provide the issue client's MAC address with us so we can have further investigation? (Few of clients is enough) You can find it in the client page, please remember to check the manufacturer display option.
Zyxel Melen0 -
Hi @Zyxel_Melen
sent you a PM with a link for the files with MACs
Hi @GiuseppeR
Zyxel Melen0 -
Hi @GiuseppeR
Zyxel Melen0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
