AVoIP Setup with Nebula
Good afternoon, sorry if any of my questions are very basic, just learning as I got thrown in the position of needing to learn to setup the networks for our AV system.
We have just switched to Zyxel and I am setting up our first couple of WyreStorm systems with them. The systems consist of a USG Flex 50, (3) GS2220-50HP switches and a NWA50AX.
The Flex 50 is really only used to give out DHCP and to give internet access to the AV network.
The NWA50AX is used used for laptop access when onsite and to provide the iPad access to the control system.
Is the Nebula Professional Pack License what I need to be able to setup these switches up for AVoIP and monitor them remotely? According to the license inventory there is a Pro Pack Bundle with an expiration of 9-12-26 assigned to the switch I am currently looking at but when I try to do any configuration under "Advanced IGMP" I get a popup saying to upgrade to the Pro Pack. Is there something I am missing?
Also, is there a setup guide available for setting an AVoIP system via Nebula.
Thank you in advance for your help.
Hi @Mark_KC
Additionally, the advenced IGMP might not fulfill the AVoIP system's requirement. Since GS2220 's latest firmware version support to configure on device local GUI and use setup Network AV related configuration, please access your switch with site-wide local credential to login and configure.
Configuration related to Network AV:
Configuring Zyxel Switch for the DANTE Network — Zyxel Community Start from Step 2.
P.S. Please ignore Wizard part since you have done the configuration on Nebula Advanced IGMP.
P.S.2. The configuration changed from local GUI will not update to Nebula. If you changed the configuration that Nebula supports, it will overwrite the configuration you made from local GUI. Ex. Advanced IGMP, VLAN, port setting, etc.
Zyxel Melen0
Hi @Mark_KC
To setup the switch for AVoIP, you will need to user the Advanced IGMP for configuration and IPTV report to monitor. According to your description, your organization is base pack organization now. Please note that to become a pro pack organization, the devices in your organization need to have at least one pro pack license. If all of your devices have one pro pack license, please help to check if there is an upgrade now button in license & inventory page.
Where do I find the PRO/Pack Upgrade button in Nebula CC? — Zyxel Community
Here is a guide for setting the advenced IGMP:
Setting up your IPTV network with Nebula — Zyxel Community
Hope this helps.
Zyxel Melen0 -
Thank you Zyxel Melen, this looks like the exact info I need. Will take a look after a few meetings I have this morning.
Hi @Mark_KC
Zyxel Melen0
- 602 USG FLEX H Series
- 481 News and Release
