5G WAN drops with FWA510
Nexion218
Nexion218 Posts: 4 image  Freshman Member
Hi!
I have been using FWA510 with LTE mode only for a while, since my area did not have 5G connection. Now that I have moved to location where 5G is possible and speeds are excellent I am disappointed to learn that WAN cannot keep connection for usually more than one day before requiring FWA510 to be rebooted. I googled the matter a bit and it seems this is known issue and still not fixed. Below is quote from another user:
“The NSA fallback bug was listed as a Known Issue in V1.18(ACGD.1)C0. The issue persists in V1.18(ACGD.5)C0, but it no longer appears in Known Issues. Please confirm whether this has been fixed, or if it is still under investigation.”
Can other users confirm if you still have problems and when is this expected to be resolved?
Best regards, LM
