WAH7601
JoeJUS
I am trying to reconfigure my SSID for my wireless router. I log in via the router address and get to the password menu. According to the information in the manual the sign and password is admin / 1234
That is not the case. I even went as far as just in case holding the reset button down so it resets to the original factory settings and the login and password any suggestions?
Hi JoeJUS,
Have you previously used the same username and password on this WAH7601? Did it work at that time? When you performed the reset, how long did you hold down the reset button, and what changes did you observe in the LED indicators?
Brandon
- 603 USG FLEX H Series
- 481 News and Release
