NR7303 I lost my sticker and can't access configuration page anymore
MattBest
MattBest Posts: 1 image  Freshman Member
Hi, I own Zyxel NR7303 and unfortunately I lost my PoE adapter that had the sticker with wifi and admin password on it (I stuck it on the adapter as the manual suggested). Now I can't access the configuration page. I've read that Zyxel can recover my password if I provide the serial number of my device, so here it is:
S240Z09005498
Thank you.
  • Zyxel_Krystal
    Zyxel_Krystal Posts: 2 image  Freshman Member
    First Answer First Comment Friend Collector
    Hi @MattBest ,
    I've provide the password to you in the private message, please check your inbox.
    thank you.
  • Zyxel_Krystal
    Hi @MattBest ,
    thank you.
