NR5307 wifi password
JonasN
Hi Zyxel, I just upgraded to the NR5307.
Its replacing a fiber connection and older Zyxel wifi router.
The network has many smart home devices connected, so SSID and password needs to match the old.
Whats the trick to freely select wifi password and not have to follow the special character requirement?
Some of the smart home devices doesn't even allow special characters, so even if I started over and reconfigured all devices, it would not work in practice.
Hi JonasN,
Have you previously used the same username and password on this WAH7601? Did it work at that time? When you performed the reset, how long did you hold down the reset button, and what changes did you observe in the LED indicators?
Brandon
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
