Widget malfunction - "Clients by manufacturers"
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
this morning I have all the ORGs with this malfunction:
How can I solve this issue?
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,535 image  Zyxel Employee
    Hi @GiuseppeR
    Sorry for the delayed update. This issue has been solved last Tuesday. We also add a monitor log to monitor this issue to prevent similar issues from happening.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR
    I checked with our team and there was no issue after we add the monitoring tool. About this issue, it is more likely the MAC address is not able to verified. I used the wireshark OUI Lookup Tool and get the same result. So, the issue is from the device's vendor, not Nebula can't verify the MAC/OUI.
    Zyxel Melen
  • Zyxel_Melen
    edited September 2025
    Hi @GiuseppeR
    I checked some of our site's clients and had the same issue.
    Could you help to provide the issue client's MAC address with us so we can have further investigation? (Few of clients is enough) You can find it in the client page, please remember to check the manufacturer display option.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    sent you a PM with a link for the files with MACs
  • Zyxel_Melen
    Hi @GiuseppeR
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I still see some "Unspecified" items….
    Health organization:
    Textile Company:
  • Zyxel_Melen
    Hi @GiuseppeR
    Zyxel Melen
Nebula Tips & Tricks
