NAT not available in my Nebula FWA510
bo_liu2963
bo_liu2963 Posts: 2 image  Freshman Member
I tried to set port forwarding to enable Remote desktop. I read all the different instructions available on the internet. They all refer to site-wide setting and then NAT. However my nebula control center has no site-wide settings or NAT. Help neede urgently. Thanks in advance.
Snr of the device: S240Z29002510
BR
Bo Liu
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,632 image  Zyxel Employee
    Hi @bo_liu2963
    Please note that the ISP normally does not provide the public IP address for Cellular network. Please check the IP address in Cellular Info. If it is not public IP, please contact your ISP to check if your SIM card can fix with a public IP.
    Zyxel Melen
  • Zyxel_Melen
    Hi @bo_liu2963
    Zyxel Melen
Nebula Tips & Tricks
