Flex 200H IPSec Remote Access VPN
Djupedal
ZCNE Certified
ZCNE Certified
Hi
I need help to set up Flex 200H IPSec Remote Access VPN.
I have tried activating IPSec Remote Access VPN, and on the client chosen Get from server. But it won't finish seting up. Error: server not found.
Manual setup won't work either.
What can I have missed?
Hi @Djupedal
To get the VPN configuration from the firewall, you need to:
- Ensure the firewall WAN has public IP. If it is private IP, you need to set NAT on the uplink router for HTTPS (443).
- Ensure WAN to Device/ZyWall allows HTTPS.
- Enter the firewall's WAN IP (or the public IP).
If the issue isn't solved, please enable Zyxel support access so we can help to check.
Zyxel Melen0
- 441 Beta Program
- 211 Nebula Ideas
- 541 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
