USG FLEX 500H - Logs broken AGAIN
Mk88_it
Mk88_it Posts: 86
image  Ally Member
edited September 2025 in USG FLEX H Series
Hello, the logs on our 500H are broken again, even with the latest firmware 1.35(ABZH.2) as you can see in the following picture
There is also a previous question tha has already been answered by @Zyxel_Judy
V1.32 500H: the logs are broken — Zyxel Community
«1
    PeterUK Posts: 4,738
    image  Guru Member
    Logs and time seems fine here can you check in USG system > settings the time is correct to windows?
    I also use windows as a time server for my USG
    ConfigureNTP Server in Windows Server 2019/2022 | ComputingForGeeks
    You will also need this set on the USG by SSH
    edit running
    vrf main ntp maxdistance 16
    commit
    copy running startup
  • Mk88_it
    Mk88_it Posts: 86
    image  Ally Member
    @PeterUK The logs and time aren't fine unfortunately…. The logs are stopped since one day after the last boot of the device
    We had the same issue with firmware version 1.32 too
    image  Guru Member
    Seems fine here like I said time matches in real time
    I suggest you test setting up windows as a NTP server and see if that makes difference?
    I know that with these FLEX H they send logs to nebula maybe your not linking to the servers correctly and its causing a problem? I know that I'm in a case where the USG fail to connect to server sometimes.
    Do you have many WAN IP uplinks?
  • Mk88_it
    Mk88_it Posts: 86
    image  Ally Member
    I don't know why, but the logs feature is completely stopped on our device. I don't think it's a problem about NTP or wan config
    No logs are sent to Nebula or SecuReporter either.
    I know how to solve the situation: reboot the device as usual 😫
    @Zyxel_Melen @Zyxel_Judy Would you like to investigate this issue? If not, I will have to reboot the device….
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,116
    image  Zyxel Employee
    Hi @Mk88_it
    PM sent. Please help to provide the org and site name and enable Zyxel support. Thanks!
    Zyxel Melen
    image  Guru Member
    One thing I'm doing different to most people is the following:
    make group with the following FQDN
    *.myzyxel.com
    *.zyxel.com
    then make a routeing rule
    incoming Zywall
    Destination Address FQDN group you made
    nexp hop your WAN interface
    SNAT none
    then reboot see if that fixes it
  • Dylan96
    Dylan96 Posts: 47
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
    image  Freshman Member
    I don't think this solution is relevant to the problem described.
    image  Guru Member
    Well it still the fact that I don't see this problem so must be doing something different if the USG is not connecting to Nebula maybe thats the reason why log locally are not happening in time.
  • Mk88_it
    Mk88_it Posts: 86
    image  Ally Member
    I think it's something related to device insight function
    image  Guru Member
    well I do have that disabled so you might be right?
