NAS542 Raid 5 - Hot Spare labeled as "not supported"
AdLo
AdLo Posts: 4 image  Freshman Member
Hey there,
I am currently using a NAS 542 with 4 drives in RAID 5. While checking my hdd health I stumbled across a small notification in my Storage Manager stating Hot Spare is not supported.
I chose RAID 5 because in case one drive dies I can just replace it and retrieve my data from the other 3 working hdds. Is this the case with my current configuration or do I have to change it?
Thank you!
  • Mijzelf
    Mijzelf Posts: 3,063 image  Guru Member
    OK, to anwer your previous question
    You running a 4 disk raid5 array, and all members are up:
    md2 : active raid5 sdc3[0] sdd3[3] sda3[2] sdb3[1]
    8778405312 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
    The roles are a bit strange (have you shuffled the disks after creating the array?) but that doesn't obstruct functionality. Your array is safe for failure of a single disk.
    Don't know where the 'not supported' message came from. Not from mdstat.
  • Mijzelf
    AFAIK the web backend reads this information from the (pseudo-)file /proc/mdstat. To know where this comes from look at the orginal.
    Enable the ssh server, login over ssh and execute
    cat /proc/mdstat
  • AdLo
    Hey,
    Thank you for your reply. mdstat outputs the following:
    Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
    md1 : active raid1 sdc2[0] sdd2[5] sda2[4] sdb2[1]
    1998784 blocks super 1.2 [4/4] [UUUU]
    md0 : active raid1 sdc1[0] sdd1[5] sda1[4] sdb1[1]
    1997760 blocks super 1.2 [4/4] [UUUU]
    unused devices: <none>
  • Mijzelf
  • AdLo
    Thanks for checking Mijzelf.
    I recently cleaned the NAS but paid attention to not mess up the order of the HDDs. As long as it doesn't mess something up I'm fine with it.
    Thanks again.
