Zyxel FWA505 - Syslog to remote server PRTG
RobertoBove
I have tested the Zyxel FWA505 with PRTG Syslog Receiver and it works well.
Syslog messages from the FWA505 (UDP/514) are correctly received by PRTG, and log events from the router appear as expected in the monitoring dashboard.
Configuration on the router is simple from the “Log & Report > Log Settings > Remote Server” menu.
My experience shows that integrating the FWA505 into a syslog-based monitoring setup like PRTG is straightforward and effective.
Hope this helps anyone considering similar setups.
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
