NAS542 Raid 5 - Hot Spare labeled as "not supported"
Hey there,
I am currently using a NAS 542 with 4 drives in RAID 5. While checking my hdd health I stumbled across a small notification in my Storage Manager stating Hot Spare is not supported.
I chose RAID 5 because in case one drive dies I can just replace it and retrieve my data from the other 3 working hdds. Is this the case with my current configuration or do I have to change it?
Thank you!
OK, to anwer your previous question
You running a 4 disk raid5 array, and all members are up:
md2 : active raid5 sdc3[0] sdd3[3] sda3[2] sdb3[1]8778405312 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]The roles are a bit strange (have you shuffled the disks after creating the array?) but that doesn't obstruct functionality. Your array is safe for failure of a single disk.
Don't know where the 'not supported' message came from. Not from mdstat.
AFAIK the web backend reads this information from the (pseudo-)file /proc/mdstat. To know where this comes from look at the orginal.
Enable the ssh server, login over ssh and execute
cat /proc/mdstat1 -
Hey,
Thank you for your reply. mdstat outputs the following:
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid1 sdc2[0] sdd2[5] sda2[4] sdb2[1]
1998784 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sdc1[0] sdd1[5] sda1[4] sdb1[1]
1997760 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>0 -
Thanks for checking Mijzelf.
I recently cleaned the NAS but paid attention to not mess up the order of the HDDs. As long as it doesn't mess something up I'm fine with it.
Thanks again.
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
