How to connect fwa701 to a fwa505
Ap_1
Ap_1 Posts: 2 image  Freshman Member
edited 5:42AM in Mobile Broadband
hi,
I can’t seem to get an internet connection from my fwa701 on my fwa505.
The fwa701 is in bridge mode (dynamic) and when it is connected to my pc I can access the internet.
Thanks for helping
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,937 image  Guru Member
    Hi @Ap_1
    Do you mean your FWA710 is using IP passthrough mode?
    What is your topology and which device can't get Internet connection? The FWA505 or the client under FWA505?
    Please provide more details so we can help you better.
    Zyxel Melen
  • Zyxel_Melen
    edited 6:14AM
    In addition, if your FWA710 and FWA505 using the default configuration and IP passthrough is disabled, you will need to change the IP subnet on one device to avoid IP conflict.
    Zyxel Melen
    PeterUK Posts: 4,124 image  Guru Member
    Is what you want a failover setup? where FWA710 is passthrough to the WAN of FWA505 and FWA505 is the router that uses FWA710 as the main internet?
