Anti-Malware whitelist file with MD5
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
I'm having issues with some file downloads: how can I add here some MD5 hashes to check issues?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @GiuseppeR
    Yes, you can type in the MD5 hashes in the allow list.
    Zyxel Melen
  • GiuseppeR
    Thanks @Zyxel_Melen
    I'll try that.
    I think I found a false positive that is blocked by your H series, it is an exe for an antimalware downloader: it is always blocked above 90% download.
    If you like I can share the downloader.
  • Zyxel_Melen
    Hi @GiuseppeR
    Thanks for the information. I will send you a private message to request the info.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR
    I want to update you that our team test with the file, but the firewall Anti-Malware doesn't block this file. Our team can open this file without issue. Therefore, we would like to check if there has any logs on the firewall related with the Anti-Malware.
    Zyxel Melen
Nebula Tips & Tricks
