Firewall status - High usage detail
Hello everyone,
is there a way to analyze what happens to a firewall when you see it under high usage?
For example, going from one ORG to another one I noticed this:
Is it possible to know why that firewall was over 90% of usage?
Just for your reference it stays on 5-10% as the average usage.
Hi @GiuseppeR
To analyze the CPU high issue, we need to dump the cup usage for each process to investigate. Below FAQ provides the steps to dump the required info for you to reference.
How to troubleshoot high CPU usage on USG FLEX H? — Zyxel Community
How to troubleshoot high CPU usage on ATP/USG FLEX? — Zyxel Community
Please help to collect and send it to me via private message.
Zyxel Melen0
Hi @GiuseppeR
Zyxel Melen0 -
Hi @Zyxel_Melen
in this moment it is in the average usage, if you want I can dump the data but I was referring to a possible tool inside Nebula to inspect what was happening. Is there something to see processes details?
Hi @GiuseppeR
The post from Cooldia is one of the command to check. You may check the post I mentioned in previous comment.
Zyxel Melen0 -
Hi @Zyxel_Melen
thanks a lot, I'll try that
- 601 USG FLEX H Series
- 480 News and Release
