Remote Access IPSEC VPN doesn't work
Jerome89
Jerome89 Posts: 9 image  Freshman Member
I did setup Remote Access IPSec VPN using SecuExtender. I can't make it work. To troubleshoot I connected the client directly to the wan network of the USGFlex200 (192.168.250.50/24) . Here is attached the SecuExtender console output. I'm a new Zyxel user, so I probably have missed something obvious in the configuration (even if I used the wizard) ?
Thanks in advance,
Best regards,
Jerome
Best Answers
    PeterUK Posts: 4,377 image  Guru Member
    So you enterer the VPN settings manually in SecuExtender?
  • Jerome89
    Hi Peter - thanks so much for this detailled answer !
    I did all of that - but you know what - I'll restart from scratch and will let you know.
    Do you know if there is a way to use pre-shared instead of certificate for remote access (it should as you have this option in SecuExtender) ? Where do you configure the pre-shared on the GW side ?
    Thanks again,
    Have a good day
«1
    With the wizard did you select IKEv2?
  • Jerome89
    Yes IKEv2. Wizard screenshots attached.
    Log are saying Self-signed certificate not accepted, on SecuExtender are you using the "get from server" under configuration?
  • Zyxel_Tina
    Zyxel_Tina Posts: 593 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Jerome89,
    Welcome to Zyxel Community!
    After analyzing, your USG FLEX is using a self-signed certificate with a private WAN IP.
    Since this is not a public IP, the VPN gateway is likely behind another router, causing the certificate validation and IKEv2 negotiation to fail.
    Please check the following:
    • Make sure the USG FLEX has a public IP or that UDP ports 500 and 4500 are forwarded from the upstream router.
    • Use a certificate whose CN matches the public IP used by the client.
    The VPN should connect if the gateway is reachable on a valid public address.
    Zyxel Tina
  • Jerome89
    Yes I tried this during my tests, without really understanding what it was suppodes to do. I guessed it was a way to get the VPN RAS Setup from the GW ; anyway it failed.
  • Jerome89
    Hi Tina,
    Thanks for your answer.
    You're right my Zyxel is behing a NAT router. But as it didn't work, in order to isolate issues & troubleshoot, I did put the client computer with SecuExtender on the same network as the wan1 interface ⇒ Client and GW are on the same Net, so no NAT is involved. So for this test, configuration (including self-signed certificate) should be consistent (?). Would it be smarter to try with the edge_certificate for testing purpose ?
    Question : In SecuExtender, Configuration/Wizard menu, IKEv2, in the 2/3 menu it's asking for a shared key or a certificate (to authenticate the GW I guess). If using a shared key where is it configured on the GW (I'm only using Remote Access VPN, no site-to-site) ? (Just to try with pre-shared instead of certificate)
    Thanks in avance,
    All the Best,
    Jerome
  • Jerome89
    Hi Peter - yes I entered them manually using the wizard.
  • Jerome89
    (Sorry the thread is still opened - I closed it by mistake - is there a way to mark it unansered ?)
    edited October 2025
    In which case you need to download the certificate USG made to the SecuExtender
    copy gateway setting to SecuExtender
    download certificate without a password
    added to certificate SecuExtender
    copy VPN tunnel setting to SecuExtender
    For the VPN to work by WAN as you are behind NAT you need to make a certificate with that WAN IP and set it to be used in VPN gateway setttings and SecuExtender.
