when logging on admin web UI, Zyxel certificate is invalid...
DAB_FR
DAB_FR Posts: 4 image  Freshman Member
Does Zyxel plan to renew public certificate used by browsers ?
current certificate is invalid.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,263 image  Zyxel Employee
    Hi @DAB_FR
    Please share your model and your detailed symptoms for us to check.
    Zyxel Melen
  • DAB_FR
    Hello
    model Zyxel FAw505
    Login to the admin interface
    Certificate expiry date on Sunday , january 8th 2023 ….
    regards
  • DAB_FR
    PeterUK Posts: 4,272 image  Guru Member
    edited October 21
    The idea is you add your own certificate to the device I don't know about FAw505 but my FWA510 the certificate import is broken? the USG I can do.
  • Zyxel_Tina
    Zyxel_Tina Posts: 471 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers First Comment
    Hi @DAB_FR,
    Thanks for your feedback. I’ve used the same model with the latest firmware to check the certificate on my side, and it appears to be the latest valid one, which is 7/9/2035. Please see the screenshot below for reference.
    Could you please let us know which firmware version your device is currently running?
    Zyxel Tina
