VLAN list disappeared in Nebula after weekend, other settings unchanged
After the weekend (20.10.2025), we noticed unusual behavior across all Zyxel switches connected to Nebula Cloud.
Symptoms:
- The entire VLAN list disappeared - only VLAN 1 remained visible in Nebula and on the devices.
- However, all other configurations, including port and trunk settings, remained unchanged.
- The PVID of all ports was reset to the default value (VLAN 1).
- The devices were not rebooted - uptime remained the same.
- The issue was first noticed at around 06:00 UTC on Monday.
- Before this incident, Nebula displayed available firmware updates, but after it happened, the update notifications disappeared.
Devices affected:
Zyxel XGS1935-52
Zyxel GS1920-24HP
Additional detail:
We recently added one more switch to the same network site, about two weeks ago.
On this newly added switch, the trunk configuration was also reset, unlike on the others.
So, the older switches lost only their VLAN table (while keeping other settings), but the new one lost both VLANs and trunk settings.
Another note:
Yesterday there was a major AWS incident.
I can’t confirm whether it’s related, but could this outage have affected Nebula Cloud services in any way?
Questions:
- Are there any known cases where Nebula Control Center might reset VLAN tables without manual admin actions?
- Could this be related to a cloud configuration sync, license level, or the process of adding a new device?
- Is there any information suggesting the AWS outage could have impacted Nebula availability or configuration storage?
We observed similar issues. Our switches were online, pingable, and even communicating with NCC. However, all connected endpoints to the switches were not connecting to our network.
We are utilizing cloud authentication by MAC address authorization via NCC. I am wondering if the AWS outage temporarily impacted cloud authentication authorizations. Once we rebooted the switches, either via locally logging into the GUI or via NCC, then the endpoints were able to connect normally again.
Hi @antornis, @BlueITAdmin,
To better assist you and help us investigate further, could you please enable Zyxel Support Access and send us your organization, site name, and the affected devices' MAC addresses via private message? Thank you for your cooperation!
Zyxel Tina
@Zyxel_Tina - Thank you. I sent you a private message. I also added @Zyxel_CSO
If there is anyone else I should include on the PM, please let me know.
@Zyxel_Tina - Still awaiting a response, how should we proceed for further investigation for the issues we experienced on Monday? Thank you!
[Update]
This issue may be due to an AWS service incident that impacted most NCC services, causing instability at the time. We apologize for any inconvenience.
Services have returned to normal operation. If anyone have further questions, please feel free to create a new post.
Zyxel Tina
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
