Firmware Mangement Date/Time Bug
George_Ward
George_Ward Posts: 6 image  Freshman Member
Zyxel Certified Network Administrator - WLAN First Comment First Anniversary
I've noticed since the update to v19.20 that the Firmware Management Date/Time Selection is a bit buggy.
So, for example, if you were to pick the 6th November, it would actually pick the 5th November, but the notice above says the 6th November. The time also seems bugged,as you'll pick 2am and it will say 1am.
See picture. If it helps, I'm using Firefox to access Nebula.
  • Zyxel_Tina
    Zyxel_Tina Posts: 697 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @George_Ward,
    Thanks for reporting this. We’ve tried reproducing the issue on our side but couldn’t observe the same behavior — the selected date and time appear correctly when scheduling firmware upgrades.
    To help us investigate this further, could you please enable Zyxel Support Access on your Nebula organization and send us your org. and site name via private message?
    Zyxel Tina
Nebula Tips & Tricks
