Zyxel Nebula SD VPN connection fails
Hello all,
any ideas on what is going wrong?
I have 3 Sites.
Two Sites have a Flex200 router, 1 Site still has a NSG100 router (soon to be replaced).
I have Hub/Spoke Nebula SD VPN connection.
Flex 200 to Flex 200 is going well.
Flex 200 to NSG 100 is not going well (Anymore, it used to work in the passed).
The NSG 100 Event log gives me:
IPsec SA negotiation failed
No proposal chosen
Tunnel [S22F4ED88D6_21] Phase 1 Local ID mismatch
I have tried to delete all VPN settings. Turn of VPN. etc.
On all 3 devices only WAN1 is enabled. WAN2 is set to None.
I hope someone has the solution?
Thanks Very Much.
Hi @IctPk
Thanks for the privilege. This is because the device's VPN configuration error that cause Nebula can't push the new VPN configuration. Please find an available time to remove the NSG from this site and add it back. This will erase the device's old configuration and push the new configuration.
Zyxel Melen1
Hi @IctPk
May you enable Zyxel support access and share the organization's name with me so I can help to check?
Zyxel Melen0 -
Dear Zyxel Melen. Thanks for your answer. The Org name is: Stichting PK
Hi @IctPk
Zyxel Melen1 -
Thanks again for your suggestions. Do I need to be on site to do this? Or is it possible to do from remote?
Hi @IctPk
It is possible to do from remote. The steps keep NSG's WAN interface setting; therefore, the device will still connect with Nebula.
Zyxel Melen0 -
Yes it worked. Very happy. Thank you very much for your support!
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 491 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
