Werkt een MQTT Broker-server op de NAS540
Johanb
Johanb Posts: 3 image  Freshman Member
Third Anniversary
Kan ik een MQTT Broker-server laten draaien op een NAS 540 modelnr:542
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Theoretically yes. The NAS has plenty of CPU and RAM. (And storage, I suppose). In practise, if you can find a statically linked binary for Linux Arm5 or Arm7, it will probably work. If it's some Python package it won't. (Python on the box is outdated, and you can't add any libraries. No pip).
    A non-statical linked binary might work, depending on it's dependencies.
