FWA505 DYNDNS in manual but not on router
mike79
mike79 Posts: 5 image  Freshman Member
Hello
I bought the FWA505 so i could use the dyndns feature , but the option are not available on the device.
in the FWA505 manual
on device there arent DynDns option is there a hidden menu somewhere ?
  • Zyxel_Tina
    Zyxel_Tina Posts: 593 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @mike79,
    The FWA505 does not support dynamic DNS. You may refer to this information in our user guide’s feature difference table.
    Zyxel Tina
    PeterUK Posts: 4,377 image  Guru Member
    If your in IP passthrough it might not show
  • Zyxel_Tina
    Hi @mike79,
    Zyxel Tina
