[NAS542] Bricked device after custom firmware attempt - Stuck at "arch_number: 1094"
Title: [NAS542] Bricked device after custom firmware attempt - Stuck at "arch_number: 1094"
Hello everyone,
I'm hoping someone can help me unbrick my Zyxel NAS542.
Background:
I tried to replace the stock firmware with a custom one (Alpine Linux). The process failed, and now the device no longer boots. I have serial console access and can interact with the Barebox bootloader.
The Problem:
When I power on the device, it successfully loads Barebox, but it fails to start any kernel I try to flash. It gets stuck immediately after printing the arch_number. This happens with both the custom kernel I built and even when I flash the official Zyxel kernel.
Here is the complete boot log from the serial console when it tries to boot:
uloader 2011.06.0 (May 20 2014 - 16:36:41) Board: Mindspeed C2000 c2k_spi_probe Copying Barebox from SPI Flash(bootopt=0) BB Copying Done Starting Barebox at 0x01000000 ... barebox 2011.06.0-svn44305-dirty6 (Aug 28 2014 - 22:25:22) Board: Mindspeed C2000 c2k_spi_probe c2k_otp_probe. cbus_baseaddr: 9c000000, ddr_baseaddr: 03800000, ddr_phys_baseaddr: 03800000 class init complete tmu init complete bmu1 init: done bmu2 init: done util init complete GPI1 init complete GPI2 init complete HGPI init complete HIF rx desc: base_va: 03e80000, base_pa: 03e80000 HIF tx desc: base_va: 03e80400, base_pa: 03e80400 HIF init complete bmu1 enabled bmu2 enabled pfe_hw_init: done pfe_firmware_init pfe_load_elf pfe_load_elf no of sections: 10 pfe_firmware_init: class firmware loaded pfe_load_elf pfe_load_elf no of sections: 10 pfe_firmware_init: tmu firmware loaded pfe_load_elf pfe_load_elf no of sections: 14 pfe_firmware_init: util firmware loaded eth_port: 0 NAS540_phy_reg_setting[eth_port].phyaddr: 0x4 miidev_restart_aneg for PHY4 eth_port: 1 NAS540_phy_reg_setting[eth_port].phyaddr: 0x6 miidev_restart_aneg for PHY6 cfi_probe: cfi_flash base: 0xc0000000 size: 0x04000000 Unknown FLASH on Bank at 0xc0000000 - Size = 0x00000000 = 0 MB bootopt = 0x0 Using ENV from SPI Flash. nand_probe: comcerto_nand base: 0xc8300000 size: 0x256 MB NAND device: Manufacturer ID: 0x98, Chip ID: 0xda (Toshiba NAND 256MiB 3,3V 8-bit), page size: 2048, OOB size: 64 Using default values Bad block table not found for chip 0 Bad block table not found for chip 0 Scanning device for bad blocks ... (skipping list of bad blocks for brevity) ... Bad block table written to 0x0ffe0000, version 0x01 Bad block table written to 0x0ffc0000, version 0x01 Malloc space: 0x00600000 -> 0x01000000 (size 10 MB) Stack space : 0x005f8000 -> 0x00600000 (size 32 kB) running /env/bin/init... Unknown command 'export' - try 'help' Disabling eee function of phy 4 ... Disabling eee function of phy 6 ... Hit any key to stop autoboot: 0 Attempting to boot custom Alpine kernel... Kernel: /dev/nand0.kernel1.bb Bootargs: console=ttyS0,115200 pcie_gen1_only=yes usb3_internal_clk=yes mac_addr=78:C5:7D:19:AE:CE,78:C5:7D:19:AE:CF root=ubi0:rootfs ubi.mtd=5,2048 rw rootfstype=ubifs Verifying Checksum ... OK Image Name: Linux NAS5xx Created: 2025-10-20 19:05:19 UTC Image Type: <NULL> <NULL> <NULL> (<NULL>) Data Size: 3988904 Bytes = 3.8 MB Load Address: 00008000 Entry Point: 00008000 OK Starting kernel ... commandline: console=ttyS0,115200 pcie_gen1_only=yes usb3_internal_clk=yes mac_addr=78:C5:7D:19:AE:CE,78:C5:7D:19:AE:CF root=ubi0:rootfs ubi.mtd=5,2048 rw rootfstype=ubifs arch_number: 1094 (...and it hangs here forever)
What I've Tried:
- Flashing the official kernel and rootfs extracted from the latest firmware
.binfile. - Building a custom kernel (v4.19) with the correct
mvebu_v7_defconfigandLOADADDR. - Using
erase_old_nand_fmtto clean the NAND. - Manually flashing the kernel and rootfs using
tftpto RAM, theneraseandcp -ato NAND. - Setting bootargs manually:
setenv bootargs 'console=ttyS0,115200 root=ubi0:rootfs rootfstype=ubifs'
No matter what I do, the kernel starts but hangs immediately after arch_number: 1094. It seems like it's failing to mount the root filesystem, but I get no "Kernel panic" message or any other output.
Does anyone know the correct procedure to recover from this state? Is there a specific combination of tools, firmware files, or Barebox commands that I'm missing?
Any help would be greatly appreciated. Thank you!
.binfile.Did you extract the kernel or the uImage? The loadaddress in your log is different from that of the stock kernel. See here.
mvebu_v7_defconfigandLOADADDRThis is not a Marvel SoC!. It's a Mindspeed Comcerto 2000. It's not supported by the vanilla kernel, and AFAIK there is no usable kernel for it at all, other than the stock one.
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
