How do I replicate a USG 100HP configuration on Nebula?
henriquev
henriquev Posts: 21 image  Freshman Member
edited October 2025 in Nebula
I need to apply a baseline configuration to 549 new sites using the USG 100HP firewall model on Nebula.
I have tried using the "clone site" feature, which works for us with the USG Flex 200 model, but it is not working for the USG 100HP. When I clone a site, the new firewall's configuration in Nebula appears blank. I also attempted to restore a configuration backup, which was also unsuccessful.
Could you please provide guidance on the correct procedure for replicating a configuration across multiple USG 100HP sites?
  • Zyxel_Tina
    Zyxel_Tina Posts: 701 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @henriquev,
    Currently, the FLEX H series does not support the clone site feature, which is why you encountered the clone failure issue.
    Workaround:
    When onboarding the new firewall, please choose “Web configure” for the first-time deployment.
    Then, go to the following page to restore the configuration file — this will allow the device to recover the same settings as your previous unit.
    Zyxel Tina
  • Zyxel_Tina
    Hi @henriquev,
    Workaround:
    Zyxel Tina
Nebula Tips & Tricks
