Device show in My devices and services but not in organization device list
hmchen
hmchen Posts: 2 image  Freshman Member
edited November 2025 in Nebula
I have an AP and would like to unregister from an organization but failed. Here is the snapshot of the device.
However, I cannot find it from the device list from the organization.
What can I do to unregister the device?
  • Zyxel_Tina
    Zyxel_Tina Posts: 525 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @hmchen,
    Welcome to Zyxel Community!
    May I know the reason why you would like to unregister the device from the organization?
    Please note that when a device is removed from an organization, its ownership still remains with the original owner account.
    If your intention is to transfer the device to another account’s organization, please use the Nebula Mobile App to scan the device’s QR code and register it again under that account.
    This method ensures that the device ownership is properly updated and can be managed from the desired account.
    Zyxel Tina
    PeterUK Posts: 4,338 image  Guru Member
    look in > License & inventory > Devices
  • GiuseppeR
    GiuseppeR Posts: 578 image  Master Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
    Hi @hmchen
    you have to go here and select "Remove from organization":
  • Zyxel_Tina
    Hi @hmchen,
    Zyxel Tina
Nebula Tips & Tricks
