Can't update entware on nas326 - failed to download package list
lucesan
lucesan Posts: 13 image  Freshman Member
I tried to update entware but I get the following error:
root@NAS326 :~# opkg update
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Downloading http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz
*** Failed to download the package list from http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz
Collected errors:
 * opkg_download: Failed to download http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz, wget returned 4.
 * opkg_download: Check your network settings and connectivity.
It looks like the repository is down. What can I do to update to latest entware?
  • lucesan
    I removed the Mijzef repository from opkg.conf and I don't get the error anymore. But as far as I understand, latest entware is not compatible with Nas326 kernel, which is 3.10, because the minimum requested is 3.2. Am I right?
  • Mijzelf
    Mijzelf Posts: 3,022 image  Guru Member
    The url should nowadays be zyxel.ddnss.eu instead of zyxel.diskstation.eu. (Sorry, domain provider went out of business.)
    Don't know about latest Entware. The Entware-ng package installed Entware-ng, with kernel support down to 2.6.32. As the NSA series had 2.6.31 for the Kirkwood devices, and 2.6.24 for OxNas, I compiled special libc packages for 2.6.24. But the NAS series, with Armv7 processors, all were 3+, so no need for custom packages.
    To make it more complicated, Entware-ng on Armv7 on some day updated itself to a newer Entware, but it does it conservatively, to port 'armv7sf-k2.6', which I translate to 'Armv7 soft float, kernel 2.6', instead of 'armv7sf-k3.2'. (And actually, I don't know the difference. The whole difference to get a 2.6.24 libc instead of a 2.6.32 is compiling it with the right config, and looking through the sources it only resulted in 2 shims which are dynamically inserted when the kernel didn't support a function. A lot has changed in the kernel from 2.6.32 to 3.2, but I think the interface changes to libc were considerably less.)
    Is it 3.1.0 or 3.10? 3.10 is newer than 3.2.
  • lucesan
    edited November 2025
    Thanks for your reply. You are very right, it's kernel version 3.10, which is above 3.2. I don't know how to check which version of Entware is actually installed but my opkg.cong file is this:
    src/gz entware http://bin.entware.net/armv7sf-k2.6
    src/gz Mijzelf http://zyxel.ddnss.eu/Users/Mijzelf/Entware-ng/binaries/armv7
    dest root /
    dest ram /opt/tmp
    lists_dir ext /opt/var/opkg-lists
    option tmp_dir /opt/tmp
    arch all 100
    arch armv7soft 150
    arch armv7-2.6 160
    The repository directory with the latest version of packages seems to be /armv7sf-k3.2
    Should I add it with a new src/gz option or I have to edit the first src/gz line? And what about the arch option?
    My only purpose is to update transmission to latest version, 4.0.6, which is in armv7sf-k3.2 directory but not in armv7sf-k2.6, but ,actually, my nas326 is working perfectly and I don't want to mess it up for a minor update.
    Thanks.
  • Mijzelf
    Sorry, I don't know if you can update from armv7sf-k2.6 to armv7sf-k3.2. k2.6 seems to be EOS, which is the reason there is no new Transmission, I guess.
    If you want to try you could backup your current installation, the whole Entware installation is in /opt.
