Can't update entware on nas326 - failed to download package list
I tried to update entware but I get the following error:
root@NAS326 :~# opkg update
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Downloading http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz
*** Failed to download the package list from http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz
Collected errors:
* opkg_download: Failed to download http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv7/Packages.gz, wget returned 4.
* opkg_download: Check your network settings and connectivity.
It looks like the repository is down. What can I do to update to latest entware?
I removed the Mijzef repository from opkg.conf and I don't get the error anymore. But as far as I understand, latest entware is not compatible with Nas326 kernel, which is 3.10, because the minimum requested is 3.2. Am I right?
The url should nowadays be zyxel.ddnss.eu instead of zyxel.diskstation.eu. (Sorry, domain provider went out of business.)
Don't know about latest Entware. The Entware-ng package installed Entware-ng, with kernel support down to 2.6.32. As the NSA series had 2.6.31 for the Kirkwood devices, and 2.6.24 for OxNas, I compiled special libc packages for 2.6.24. But the NAS series, with Armv7 processors, all were 3+, so no need for custom packages.
To make it more complicated, Entware-ng on Armv7 on some day updated itself to a newer Entware, but it does it conservatively, to port 'armv7sf-k2.6', which I translate to 'Armv7 soft float, kernel 2.6', instead of 'armv7sf-k3.2'. (And actually, I don't know the difference. The whole difference to get a 2.6.24 libc instead of a 2.6.32 is compiling it with the right config, and looking through the sources it only resulted in 2 shims which are dynamically inserted when the kernel didn't support a function. A lot has changed in the kernel from 2.6.32 to 3.2, but I think the interface changes to libc were considerably less.)
Is it 3.1.0 or 3.10? 3.10 is newer than 3.2.
Thanks for your reply. You are very right, it's kernel version 3.10, which is above 3.2. I don't know how to check which version of Entware is actually installed but my opkg.cong file is this:
src/gz entware http://bin.entware.net/armv7sf-k2.6
src/gz Mijzelf http://zyxel.ddnss.eu/Users/Mijzelf/Entware-ng/binaries/armv7
dest root /
dest ram /opt/tmp
lists_dir ext /opt/var/opkg-lists
option tmp_dir /opt/tmp
arch all 100
arch armv7soft 150
arch armv7-2.6 160The repository directory with the latest version of packages seems to be /armv7sf-k3.2
Should I add it with a new src/gz option or I have to edit the first src/gz line? And what about the arch option?
My only purpose is to update transmission to latest version, 4.0.6, which is in armv7sf-k3.2 directory but not in armv7sf-k2.6, but ,actually, my nas326 is working perfectly and I don't want to mess it up for a minor update.
Thanks.
Sorry, I don't know if you can update from armv7sf-k2.6 to armv7sf-k3.2. k2.6 seems to be EOS, which is the reason there is no new Transmission, I guess.
If you want to try you could backup your current installation, the whole Entware installation is in /opt.
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
