MAC Filter whitelist on Access Points
nielsscheldeman
nielsscheldeman Posts: 100 image  Ally Member
This morning I was at a client and I had to create wireless network on sensitive network unfortunately(no cable possible). Created decent password and only allowed 1 AP to send out, but in the early days I used to work with a MAC Filter list where I could work with whitelisting. I don't seem to find this on Nebula anymore except for Captive portal? But this won't work as the client is an old Win2000 machine (no internet access on the SSID of course, only intranet)
Still possible or not?
  • Zyxel_Tina
    Zyxel_Tina Posts: 719 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @nielsscheldeman,
    Nebula does not have a “MAC Filter list”. However, to fulfill your requirement of allowing only specific devices to connect to a particular SSID, Nebula supports a MAC-based Authentication feature that provides similar control.
    You can refer to this FAQ for detailed setup instructions.
    Zyxel Tina
Nebula Tips & Tricks
