Help Needed: Restoring Zyxel NAS542 to Factory State After Failed os Attempts
hi
I'm hoping to get some expert advice for my Zyxel NAS542. I've spent趋势 a lot of time trying to install a custom OS (first OpenWrt, then exploring Alpine Linux and Debian) but have run into several roadblocks. After this long journey, my primary goal now is to perform a full, clean factory reset of the device.
My Journey So Far:
- I have a working UART (serial adapter) and can access the Barebox bootloader.
- I understand the device has a dual-firmware layout (
kernel1/rootfs1andkernel2/rootfs2). - I have tried booting various
initramfsimages via TFTP with some success in getting a temporary Linux system running in RAM. - I made some changes to the Barebox environment using
setenvandsaveenv, which I now want to revert to the absolute factory defaults. - My attempts to analyze the stock firmware's UBI filesystem to extract the default
/envfiles failed due to limitations in my WSL2 kernel (missing UBI/UBIFS module support).
My Goal:
I want to completely restore the device to its original factory state. This involves two main steps:
- Resetting the Barebox environment to its compiled-in defaults.
- Flashing the official Zyxel stock firmware over both system partitions (
mtd5andmtd7).
Where I Need Help / My Specific Questions:
I have a solid plan, but I would be very grateful if someone could confirm it or provide some crucial files.
- Resetting Barebox Environment: My version of Barebox does not have the
env -dcommand. My plan is to boot into a temporaryinitramfsand then runflash_erase /dev/mtd2 0 0to wipe the environment partition. Can anyone confirm thatmtd2is indeed the correct partition for the Barebox environment on the SPI flash? - Flashing Stock Firmware: My plan is to boot into the same
initramfs, TFTP the officialstock.binfirmware to/tmp, and then runmtd write /tmp/stock.bin /dev/mtd5andmtd write /tmp/stock.bin /dev/mtd7. Is this the correct and safe procedure? - Crucial Files (The Most Important Request): I saw a post by a user named "stein_990" who mentioned that another user, Mijzelf, had provided backup files for the SPI flash (
nas520_mtd0,nas520_mtd1,nas540.mtd2). Would anyone in the community be able to share these files or a full 1MB SPI flash backup for the NAS542? Having these files would be the ultimate safety net in case anything goes wrong with the Barebox environment.
I've learned so much from reading through these forums, and I'm amazed by the expertise here. Any confirmation, advice, or files you could provide would be incredibly helpful.
Thank you in advance for your time and help!
Best regards,
stronghold
https://community.zyxel.com/en/discussion/30409/nas542-dead-spi-flash-dead-barebox-dead-uloader-dead#latest
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
