Multy X WSQ50 latest firmware
harppa67
harppa67 Posts: 3
image  Freshman Member
Hello, I'm having problem setting up Multy X through the app on Android.
Will You be so kind and provide link to the latest firmware and instructions as it seems to be the solution that helped others.
thank You
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,254
    image  Zyxel Employee
    Hi @harppa67
    The guide is sent to you via the private message.
    Zyxel Melen
  • harppa67
    harppa67 Posts: 3
    Thanks, now it works great!
  • teso
    teso Posts: 4
    Hi, can you send me in private message link for the firmware?
  • Bjan
    Bjan Posts: 2
    thank You
  • s_p2003
    s_p2003 Posts: 4
    Hello, could I also have the guide? Since I reset the WSQ50, it is no longer usable!
  • Sergey_11289
    Sergey_11289 Posts: 3
    Dear Zyxel Support Team,
    I would like to request the latest available firmware for my Zyxel Multy X (model WSQ50).
    Currently, the device requires a firmware update, but the update is not available through the mobile application, and there is no downloadable firmware file on the official website.
    Please provide the latest firmware version along with instructions for manual installation.
    Device model: Zyxel Multy X (WSQ50)
    Thank you in advance for your assistance.
  • BrianJ
    BrianJ Posts: 4
    hi support
    I have the same problem . and I need firmware for WSQ50 . not working in android app.
    Where can I get it ???
    regards
    Brian
  • infino
    infino Posts: 4
    I can’t find the latest firmware anywhere — all the links seem to be removed.
    Could you please send me the firmware via private message?
    Thank you!
