"SSID by usage" showing more SSID than expected
GiuseppeR
GiuseppeR Posts: 683 image  Guru Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
on a site I have 3 SSIDs.
Let me call them Red, Blu, Violet.
On the "SSID by usage" widget I see 2 times the Red SSID instead of only one:
Why is it showing double SSID?
  • Zyxel_Tina
    Zyxel_Tina Posts: 719 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @GiuseppeR,
    For the "SSID by usage" widget, the system does not group traffic solely by SSID name. It also differentiates usage based on the security mode actually used by the client. If your SSID is configured with WPA3 Transition Mode, clients may connect using either WPA3 or WPA2 (fallback). When both types of clients are present, Nebula will count them as two separate entries in the widget, even though they belong to the same SSID. This might explain why the “Red” SSID appears twice in the widget for a single SSID name.
    Additionally, you can check the details under Site-wide > Monitor > Access points > Summary report, and refer to the “Top SSIDs by usage” section, as shown in the example image below.
    Zyxel Tina
  • GiuseppeR
    Hi @Zyxel_Tina
    thanks for letting us know this detail, that is the answer also for my case:
    Do you plan to update the widget with the specific detail regarding the security protocol that is used or not?
    Thanks in advance for the info 😁
Nebula Tips & Tricks
