Can't see SMS and Cellular technology access menu on FWA505
enneale
enneale Posts: 2 image  Freshman Member
Good morning,
I recently bought a FWA505 instead of my beloved 5398-m904.
However, even after several restorations I notice some oddities: I can't see the text messages, and not even to correctly choose the network access technology as per the screen that I attach.
Is my product flawed?
Thanks in advance
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,622 image  Zyxel Employee
    edited December 2025 Answer ✓
    Hi @enneale
    The FWA505 allows you to manage SMS and select network access technology via its local web interface.
    To view and send SMS messages:
    1. Access the FWA505's local web interface.
    2. Go to `Network Settings` > `Broadband` > `Cellular SMS`.
    To choose the network access technology:
    2. Go to `Network Settings` > `Broadband` > `Cellular Band`.
    3. Set the `Preferred Access Technology` (e.g., `NR5G-SA/NR5G-NSA/4G (Auto Switch)`). The FWA505 supports 3G, LTE, NSA, and SA.
    Please ensure your FWA505 has the latest firmware.If you are still experiencing issues, please provide record a video for us to check. You may try the browser plug-in Jam from Jam.dev to record.
    Zyxel Melen
  • Zyxel_Melen
    Hi @enneale
    Zyxel Melen
