Connecting USB-to-RJ45 2.5/5Gbps dongle to NAS542
Is this possible to get worked USB-to-RJ45 5Gbps dongle, connected to NAS542 through rear USB slot?
If not, is there a possibility to overcome 1Gbps LAN speed at NAS542?
Probably not. In Linux all drivers are distributed in the kernel source tree. When I'm not mistaken that box runs a 3.2 kernel, which means it won't support any hardware which needs newer drivers than available in 2012. I don't think that dongle already existed, back then.
Further not all available drivers were compiled, just them needed to let the box do it's designed job. I have compiled some extra modules using the firmware GPL sources, when I wanted to connect an USB sound card, which you can find here. I didn't test most of the modules, of course.
Yes, there is. You can trunk the 2 ports, and connect them to a managed switch which also supports trunking. This will give you a 2Gbps connection. Per stream you have only 1Gbps available, but you could have 2 1Gbps streams simultaneously. That's how trunking works.
Thank you, Master.
P.S. Link you provide is probably dead (zyxel.ddnss.eu - DNS_PROBE_FINISHED_NXDOMAIN)0 -
Maybe try another DNS? It works for me.
Yes, it works with CloudFlare DNS. Thank you.
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
