Allowing WAN to LAN traffic via a ZYXEL EX3301-T0
I am trying to communicate with a device on my LAN from the internet.
I have a static IP, and the IP listed on my routers GUI matches that visible from the internet (for example, via a 'find my ip' service).
I have attempted allowing Ping access to my network. I have:
- Created three Protocols:
a) Name: PingTest
Ports/Protocol Number: ICMP: 0 /Echo-reply
b) Name: PingBack
Ports/Protocol Number: ICMP: 8/Echo-request
2. Added Access Control List Rules:
a) Source IP: Any/32
Destination IP: Any/32
Service: Ping
Action: ACCEPT
b) Source IP: Any/32
Service: PingBack
Action: ACCEPT
I expected the above to allow ping interaction from the internet to my routers IP. When I ping my routers IP, I receive no response. 100% packet failure.
Could I please ask what I am missing ?
Cheers.
You need to check whether "PING" is enabled in the settings on the remote management page.
I think first you need a port forwarding for the special needed service of this LAN device and then you can test it with a ping to these ports from outside WAN .
Thankyou Liba. Unfortunately, the 'remote management' section, as mentioned in the Zyxel help manual, is not accessible in my routers GUI.
Any further joy on this? similar issues and lack of progress for the EX5601-T0
As @BrownianBridge did, I setup the protocols for ICMP echo request and reply; added ACLs for this (not actually sure if I wanted WAN to ROUTER or WAN to LAN so tried each, without joy)
Has anyone (with the under-norished router GUI/ssh) got tcpdump to work? its a command thats listed but I can't get it to run. (some sort of nailed down syntax I'd guess.)
- 589 USG FLEX H Series
- 478 News and Release
