Anti-Malware whitelist file with MD5
Thanks @Zyxel_Melen
I'll try that.
I think I found a false positive that is blocked by your H series, it is an exe for an antimalware downloader: it is always blocked above 90% download.
If you like I can share the downloader.
Hi @GiuseppeR
Thanks for the information. I will send you a private message to request the info.
Zyxel Melen0 -
Hi @GiuseppeR
I want to update you that our team test with the file, but the firewall Anti-Malware doesn't block this file. Our team can open this file without issue. Therefore, we would like to check if there has any logs on the firewall related with the Anti-Malware.
Zyxel Melen0
- 211 Nebula Ideas
- 543 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 465 News and Release
