NR5101 - Cell Sites - upload .csv files
Dahl
Hello
I try to upload a .csv site to the app, so i can see the celle sites i have entered in the .csv file.
I have made i correct, and when i load it, nothing happens.
Does this service still work? - or is it discontinued.
Regards
Hi Dahl,
Could you share your CSV file so we can check whether the format is correct?
And also your APP version
Thanks.
- 589 USG FLEX H Series
- 478 News and Release
