Sharing is disabled and trash cans are turned on.. Samba replacment?
I have a 325 and the problem is that the shares on the second hard drive keep disconnecting and the recycle bin is activated. I suspect it's somehow related to the Samba replacement and wanted to reinstall it, but unfortunately, the command /opt/bin opkg.update command not.found returns "I'm logged in as root." Does anyone have any advice?
the command
/opt/bin opkg.update command not.foundreturns "I'm logged in as root."To be honest it's not clear which command you exactly tried, and what the result is.
And the first one doesn't? In that case I would check if it's not the disk itself which is causing problems. The command
dmesgshows the kernel log, Have a look if it contains I/O or filesystem errors.0 -
The opkg issue is solved it was a path problem. now i can use opkg without going to opt/bin
but the source is old(zyxelstation..) have you e new webseite .
the second hard drive ist the newest one ist an seagate for nas, the other on is Western digital red. the first one shares are fine. In tweaks process monitor there are three samba replacment conf, is that ok?
I think it happen every boot that zyxel set recycle bin and than the share is off.
the last: from dmesg :
invoking softwareStaggeredSpinUp()..., it will delay 5 seconds to spin up the second harddisk
every time i use dmesg. I see no I/O things here is the log
root@NSA325 -v2:~# dmesg
Linux version 2.6.31.8 (root@BuildMachine ) (gcc version 4.3.2 (sdk3.3-ct-ng-1.4.1) ) #2 Fri Jun 23 11:03:47 CST 2017
CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
CPU: VIVT data cache, VIVT instruction cache
Machine: Feroceon-KW
Using UBoot passing parameters structure
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 131072
free_area_init_node: node 0, pgdat c0868014, node_mem_map c0888000
Normal zone: 1024 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 130048 pages, LIFO batch:31
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 130048
Kernel command line: console=ttyS0,115200 mtdparts=nand_mtd:0x100000(uboot),0x80000(uboot_env),0x80000(key_store),0x80000(info),0xA00000(etc),0xA00000(kernel_1),0x2FC0000(rootfs1),0xA00000(kernel_2),0x2FC0000(rootfs2) root=/dev/nfs rw init=/init
PID hash table entries: 2048 (order: 11, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 506752KB available (5360K code, 302K data, 2872K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Console: colour dummy device 80x30
Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Feroceon L2: Enabling L2
Feroceon L2: Cache support initialised.
invoking softwareStaggeredSpinUp()..., it will delay 5 seconds to spin up the second harddisk0 -
Yes. zyxel.ddnss.eu/Users/Mijzelf
Yes. That are threads of a single process.
Did you disable the recycle bin before installing ZyXELSambaReplacement? It doesn't support a recyclebin (the plugin lacks), and actually, I cannot remember how it behaves when you start it with recyclebin activated.
That can't be complete. It only contains the first few seconds after power up. Possible I/O or filesystem errors can logically only be detected after the disks have spun up.
- 589 USG FLEX H Series
- 478 News and Release
